FOR SALE: 1933 Walsh [before the merger with Standard] with correct early rim extensions and air filter. Buzz-coil ignition with Model T coil. 6 volt lantern battery was left in battery box for extended time so the coil will need new points due to corrosion. I didn't get the starting crank but engine has good compression. Amateur brush-on paintjob doesn't look too good but nice solid tractor worthy of a good paintjob. I've owned it 3 years this month and haven't done anything with it. Been inside - dry storage. I've moved to town and need the room. $350 cash on pickup. Chillicothe, Missouri.
