Yep it will I balanced it on my lap the last one I did I don't recommend itWait till you handle the rear diff. That thing will send a man to the chiropractor.
I got new fuel fitting for those tank if you want one you can have oneNice! Seeing what the Acetone did I think if I fill the baffle area and let it soak then swish it around the rest of the tank, the Red-Kote should seal the tank good. Still in the process of removing Tins. Found some rot I'll need to take care of also.
Looks real good, Larry! No rust pinholes fortunately!Still working on the gas tank. Several rinses with Acetone and water, I let the Acetone set for several hours while rotating the tank. Then another 24 hours in Evaporust. Final steps will to be to rinse in Acetone one more time, then coat the tank.
