Looks like I won't need to borrow a bigger trailer. Got them out this morning and gave them a good soapy bath, then a wax. Decided to try and load them up. Roper went blower first, and that didn't work, the JD wouldn't fit. Tried the JD first, and the Blower wouldn't clear, so I tried backing the Roper, just spun at the top of the ramp. Got a come along hooked up and got them to squeeze on there. not enough room for the cart, but it can go in the back of the truck, and I can put the cooler on the trailer. I also made a better pin for the cart as it rattled a lot. Put a peice of rubber tube over a pin, and drilled a hole in it for a clip.
