With the help of quite a few folks I got enough measurements to start building a mount for my 48" blade to go on the 316. I have the blade A-Frame made up so far. the main frame parts a 2" X 3/16"channel.
Here's what I had made up for the angle latch:
Here's one side of the frame with the hole drilled for the pivot. The scribe mark is where it will be bent in.
I needed a 20° bend. I notched the sides and used the 20 ton press to make the bends.
I made some layout lines on a piece of plywood and put the parts together.
I clamped it all down to the plywood and proceeded to weld it up.
Fit's on the blade just fine.
Now I need to find some 1/4" plate to make the mount for the tractor. Then I can figure out the mounts for the hyd. cylinder for the lift. This may take a bit, I have a place to go for the metal, but it will be next week before I can go.
