This poor tractor took some major cutting.
Someone decided since all they had was a small pan Kohler from a Cub to replace the big pan that went bad that they would cut the motor mount plate out,cut the rear front axle support out and cut the front axle rear support area away. Then they thought in its place they should weld a piece of flat metal from the underside of the frame to the back of the front axle....solid...with no way to pivot!
Then they started welding square tube stock to where the motor mount area used to be to to mount the small pan engine and finally decided it wasn't working and quit on it.
