A few things from work
Cat385B
Knighted as Sir Cat, Vanquisher of Spam
Just some stuff at work that is new to us.
Krypto Klaw, a quick attach bucket with a built in thumb that runs off the auxiliary hydraulics:
A6867678-1C8F-43EF-B607-1E7773A18874.jpeg720C3C21-98E1-4B60-83D5-B388DFE86A0E.jpegFE3B91D1-EDD9-433E-BC54-608332EAF677.jpeg
A 390F: (the vault is 27,000 pounds)
F2A2001D-61B6-435E-AD4C-D3CC16133C42.jpegB8F65A7C-98DB-4489-9C6F-591FDD899698.jpeg50329595-4A3A-4B88-9E5C-1203C3F61B8E.jpeg32E7ED41-DED8-428A-BA2C-127DDC2711EC.jpeg
Our lowboy driver hauling the water wagon west coast style:
Water Wagon ? ? Takes a machine like that to haul water ? Got to be more to it than meet's the eye.
That thumb bucket combo looks great for building rock walls.. how does it dig dirt? The bucket has straight side leading edges with notches even?? (Shudders) very inefficient, at least it would be here in the northeast.
We got to use an Alpine Rockwheel last Thursday.
I didn’t get a pic, the above is a stock photo from Alpine’s website.
ROCKWHEEL ROCK & CONCRETE GRINDERS | Rock Grinding and Drum Cutters
Ours has a steel body between the tines and the quik attach (the black frame between the grey and yellow above) that is 13’ long. There is 3” steel pipe running down the back that we pump grout through.
The idea is to solidify the soil from the surface down to bedrock, before we start installing the lagging wall. So we were not using it for it’s intended purpose. But, it was able to mix the soil and grout down to the bedrock.
The building on the left has historical status, and it also houses backup power and servers for the Federal Reserve Bank. To the right of the steel ‘H’ pile is where the new building is going.
Example of a lagging wall:
We are going 34’ deep down from ground level. Even with the piling being 45’ deep, you still get deflection one way or another. Hence, mixing grout into the soil. Tomorrow, they will drive anchor rods thru the grout soil into the bedrock. Then we can start excavating.
Normally we would not have to go to such extremes, but the layers are 10’ of contaminated soil, 12’ of limestone, then sandstone after that.
We had an old cat 777 water truck to water the tram roads around the strip mine. It held a huge amount of water. Took forever to fill it up. The operator could turn the roads into a mud bog real quick if he wasnt paying attention.
It was an old girl, not the same one but looked real close to this one.watertruck.jpeg
