Adding pulse pump to Kohler motor
TAHOE
Just wondering if anyone has ever added a pulse pump to an engine that did not come with one. The Kohler in the free JD mower I have is knocking real bad, I got a good running engine for it, but it does not have a pump and gas tank is mounted under seat. It has the boss for one, a friend told me to drill into the case and add a barbed fitting to add a pulse pump. I have seen 2 videos on YouTube and they seemed to work, just wondering your thoughts.
I also read not to drill valve cover on the Kohler command single as the pressure inside valve cover is not consistent.
I also wonder if I drill out the boss, would cam have the lobe on it to run the pump from knocking motor and I could just mount it on there?
Here is my block.
olcowhand
Daniel In KY
Administrator
#2
I would just add an electric fuel pump and be done. The great thing about electric is if engine sits a while the bowl dries up and takes a lot of cranking to fill the carb if it has a vacuum pump. An electric fills the bowl in a couple seconds. Here is what I use. Never had issue with this pump overpowering the float/needle. Less than $9 delivered.
TAHOE
I would just add an electric fuel pump and be done. The great thing about electric is if engine sits a while the bowl dries up and takes a lot of cranking to fill the carb. An electric fills the bowl in a couple seconds. Here is what I use. Never had issue with this pump overpowering the float/needle. Less than $9 delivered.
I would just be worried it would be too much pressure for float and flood carb. I have a couple pulse pumps, that's why I was asking if this would work.
olcowhand
Daniel In KY
Administrator
#5
Yes Marty, you can drill and tap a hole for a pulse fitting. I would go through one of the bolt holes and tap with a 1/8" npt tap. The through hole wont need to be more than 1/8". Drill and tap the npt first, then blow out debris. When you drill the through hole, put a small bit of grease on the drill bit to catch the bits of aluminum.
