Allis deck on to the Country Squire
MNGB
Got the deck off the Allis this morning it looks ok the LH blade was hitting the baffle a couple of wacks with the ball peen hammer and it good to go, measured the deck its a 40" so it good I wanted a 38" to 42" couldn't be better. Slide it under the CS kind of lined it up and it going to be just like factory just need to fabricated a couple of hitch mounts and a lift the CS mule is just right
Can you take the tilt from the AC front axel and use it, if not I have a junk front axel that you could have for shipping.
Thanks Rad, I have everything on the Allis the mount is part of the mule drive and I'm going to look into removing it and checking it over but on the other hand it will not be hard to attach a mount to the CS mule drive the Allis/Simplicity deck is very similar to the PK deck so no real engineering problems just a bit of fabricating and figuring out the right length belt and of course the lift going to look at the Allis or a Simplicity lift see if it can be retrofitted
Welded the hitch mounts onto the PK hitch assy put a couple of bolts in and ran the CS out for a test drive and its going to be good, now to figure out the right length drive belt and to see if its going to mow
20220630_093123.jpg20220630_093146.jpg20220630_093157.jpg20220630_093205.jpg20220630_093214.jpg20220630_093138.jpg
Hooray it mows found a belt the right length after several tries fired up the CS drove out and engaged the deck runs smooth so off for a trial cut, it mows good made a couple of rounds decided I should have the hearing protectors so got them much better mowed another 15 minutes and it was time to get home and help Sharon. I'm very happy now just have to modify the hitch mounts to move the deck forward a couple inches and then hunt down another belt Went back to the shop and mowed another half hour its a keeper, after mowing now I think that it could handle a 48" deck
