So, the other day I welded extensions on my original paddles in the thrower. I closed the gap from about 1/2” to 3/16”. Can’t really say I saw any difference in throwing snow.
Today I installed two extra paddles. And the gap on those is also about 3/16”.
I did not use rubber as most people do, because the gap on the paddle where it enters the exit hole was 1/2”, but the gap where the paddle exits the hole is only about 3/16”. So when I welded in the extensions on the original paddles they closed up the entering gap nicely but would not pass the exit hole at the end. So I had to cut off enough so the drum would rotate. Any way, if I had used rubber, they would have to be cut off too or they would have jammed up the thrower.
