Bolens 1054 problem
qKicker
New Member
Hey all. I was mowing with my 1054 for about 15 minutes and everything was good. Then started to gradually start sputtering and bogging down. I disengaged the deck and idled down, and when I tried to re engage the deck, it died. It did this a few more times. Also when this started, when I increased the throttle, it was stumbling and cutting out. Any input would be appreciated. Thanks!
Sounds like a fuel delivery problem, some hings to check good fuel flow to the carb fuel filter, clogged fuel hose gas cap not venting , sometimes there is a finger screen in the tank that can clog, if it has a fuel pump check that its pumping
