I saw no other way to get the starter removed other than pulling the engine. Had to take the dash off to do that. Hooked up the hoist.
Had to get creative with the driveshaft removal.
It's out.
Thought the rear seal was leaking but I think the oil came from here instead. If you look at the pic of pulling the driveshaft, you can see this hose rubbing against the block.
Made quite a mess, must have been leaking for a while.
Here's the back of the engine, you can see where the oil 'washed' the pan.
Flywheel screen has an issue.
It's out.
