The starter on the Viking GT I purchased last broke a couple of weeks ago, the gear on the starter broke in half. I decided to order a new starter rather than replace the front end. New starter arrived and I installed it, the third time I started the tractor, after installing it the same thing happened to the new starter, broke the gear into 3 pieces. It was the correct starter for the motor, 16 tooth gear for an aluminum ring gear, I have a replacement starter coming, but will be reluctant to install it till I find the cause of breakage. Any suggestions as to what I should look for.
