After plowing the first time this year and having too much flex between the A frame and 10" sleeve hitch plow with the sleeve hitch adapter, I fixed it. I took Kenny's method and tweaked it so that I could get it done in time. I cut the sleeve hitch piece off and welded a new plate on it with 1/2" holes, instead of cutting the plow beam itself, which I really wanted to do lol. The 1/2" U bolts are Carry On trailer axle U bolts for 2" square axles, which I would not ever use on a trailer, but for $10 decided to use them on this plow. The plow A frame I had off another 12" brinly plow I converted to fit receiver hitch of a Cat 1 receiver hitch so my buddy could plow with his Satoh Buck tractor. Also, I painted the plow and upsized the gauge depth wheel from 10" pneumatic to a 13" flat free that I bought at Harbor Freight for around $20. And yes I painted with zero prep work, it is an implement I use after all. Still need to test this out but initial thoughts it feels like it will work well.
