made 1/2 a day seat time finally as i wanted to make a start on the big garden digging it up and getting rid of all the clump grass and a few weeds . I want to try to keep it semi prepped for spring should make it a tad easier come spring,
these are the 4 tools i used to do the job , 1st used the single tine to bust it up and tear the grass out one on the right , the next was the 4 tine cultivators at the rear of the photo .
<then used the rigid harrows to pull all the debris and larger stones out into a pile for later mulching to put back in the ground , finally i used the moldboard just to cut the bottom edge to tidy the edge up
i did get a touch over 1/2 done so far , the nest photo is some more stones i picked up after i was finished
the right hand pile is all the grass i remover for mulching later on , the left side is some left over from last summer .
here is the two tractors i used
