My dad passed away a few years ago and I brought his little lawn tractor back home. Although it’s small it is probably one of my favorites to ride and cut grass. It maneuvers flawlessly, cuts good, turns on a dime, and easy on gas.
The problem is the deck won’t disengage. While searching on YouTube I found that this same deck is used on a lot of other tractors like Poulan, Husqvarna, and a lot of Sears. They have the same flaw on the idler arm. After years of wear the idler arm gets two half round divits worn into the plate causing the deck to not disengage. This part is available at around $20. plus shipping but can be repaired.
I tack welded a few places on top of each divit then used my grinder to clean it up then painted.
