Craftsman gt4000 pto switch
Rrrdad
New Member
Can anyone help locating a pto switch for my craftsman gt4000? Tractor model number is 917273221. Switch has seven prongs. Thank you
I should start out by saying the pto is not working. Initially I thought if I wiggled the switch it would activate the pto but it just may be the pto itself. Any trouble shooting ideas?
Welcome to the forum. Here's an Owner's Manual for that tractor. It has a wiring diagram and parts list in it also. There is a relay hooked in with the PTO wiring. If you can unhook the connector at the PTO clutch and jumper (+) & (-) to that, you should be able to hear the PTO work (engine OFF). Sometimes, it's just a matter of corroded connections, possibly at the switch, relay, or the PTO itself.
