you got some nice attachments there , i like how snug the winch fits behind the tractorHere's a couple of mine....I seem to build them more than use them ( The log arch uses wheels as well & the 3500lb winch on the heavy hitch is used on it as well with log tongs
i bet that blade has pushed a cubic yd or two of material ,and yes DAC there is good engineering and workmanship in all the implements postedWell after today I finally saw this thread and my favorite got a workout today! The hydraulic blade on my MF8E is mine! I've been using it 25+ years and it was on the tractor when I got it. Through the years I tweaked it but last spring I did some major changes to it. The geometry was always messed up and I couldn't angle the blade because of it. The blade was also rigid. It couldn't "float" and that created a lot of problems plowing snow and smoothing dirt and gravel. I corrected that but still need to figure out how to angle the blade while sitting on the tractor. One of these days!
I love the designs and functionality of the stuff you guys have built!
Shane
I am building another front scoop for my tractors right now.....Its coming along slowly, will probably take most of the winter to do it with the cold and an unheated shop.
Love the wood prototype I've done the sameI am building another front scoop for my tractors right now.....Its coming along slowly, will probably take most of the winter to do it with the cold and an unheated shop.
