I had a 15 gal barrel that teet dip originally was shipped in.
It’s been hanging around for a while and I needed a way to get down the rows and provide water.
Some old displays from work provided the 1” sq tubing, a piece of 1/2” rebar for the top, the 3 pt pins mount to some old safety tabs from pallet racking and the pins themselves are old MH wheel to hub bolts. Hoses from an old washing machine
The aluminum tube for the wand came from an old swing & big band curtain frame (Nick Roy of local Greensburg PA fame)
The only purchased parts were the bulkhead connector and the brass pipe to hose bib adapter.
Gravity provides flow and shutoff.
No pump, no wires, no valves... no failures.
