I got my Simplicity 7117H that has been repowered with a Kohler 20hp Magnum out the other day. It’s always ran perfect but recently started bogging down when under load like going up a slight hill. It also would not take full throttle.
I noticed the fuel filter wasn’t filling up like it normally does. I seen a few pieces of debris in the tank so I removed the tank, shook the debris out, the tank was clean, I installed a new tank grommet, new fuel lines, and new filter. Once I hooked everything back up no fuel flow even blowing in the tank to create a little pressure. Once I disconnected the fuel line at the pump fuel started flowing out of the hose.
Can there be a vapor lock maybe between the exit side of the fuel filter and pump or pump going bad.
Even when the engine is running there’s just enough fuel in the filter to keep it running unlike before the filter would stay full of fuel. All of my other tractors once the fuel shutoff valve is open the filter will fill up, not this one.
