This morning I got the poor old Case 222 in from out in the elements, got it close to the shop door washed it down quick and got about 75% of the grease and oil off it, pushed it into the shop, these darn Case's push hard or I'm getting weak. The top engine cooling tin over the head is missing, the points cover like wise. Connected a battery to the cable and tried the starter it turned about a turn and stopped tried again got it over compression and it stopped, misc stuff was coming out of the flywheel area got the blow gun out and blew out a bunck of thistle fluff and other leaves etc no mouse nest, removed the spark plug and tried cranking it turned over good, so checked for 12 vo;ts to the coil, there was next checked at the points was good so hooked up the spark tested cranked it over nothing, shot some cleaner on the point nothing got the points file out and that did it now had spark so I screwed the SP in squirted a bit of gas into the carb and cranked it after a couple of turns it fired and ran on the bit of gas tried it again and it fired and ran for short bit, so there's hope. After fired up it cranked much better I think the ACR was stuck and is now loose cause it has no problem spinning it over. Next I'll remove the deck and hook up a temp gas tank and see if it will start and run.
