HEAVY DUTY POST HOLE DIGGER / AUGER, UP TO 60HP
ITG/AUTOTECHGEAR MODEL: 01-082, 2013
ALSO SOLD AS BUSH HOG IN THE LATE 1980'S TO EARLY 2000'S
THE GLEASON CONIFLEX GEARS IS WHAT SETS THIS APART FROM ALL OTHER BRANDS.
- CAT-1 & CAT-2, 3-POINT HITCH MOUNTING
- 3-HOLE BOOM POSITIONAL ADJUSTMENTS
- HEAVY DUTY GEARBOX, DUCTILE IRON CASTING
- GEARBOX GEARS: GLEASON CONIFLEX, CASE HARDENED
- GEAR RATIO: 3:1
- PTO INPUT SPEED: UP TO 540RPM
- SHEAR PIN PROTECTED PTO
- INPUT SHAFT: 1-1/4-INCH
- OUTPUT SHAFT: 2-INCHES
- AUGER: 9-INCH DOUBLE FLIGHTING, P/N 00767674 or TSC
- CUTTING EDGE SET P/N 01430650 or TSC
- DRILLING DEPTH: 42-INCHES
- PHD ACCEPTS AUGERS 6-INCH TO 24-INCH SIZES
- PHD WEIGHT: 165-LBS
- AUGER WEIGHT: 38-LBS'
PINS MOUNTED INWARDS FOR CAT-1, OUTWARDS FOR CAT-2 AS SHOWN IN THE PICS.
IDEAL FOR TRACTORS 24 TO 60 HP.
NOTICE: THIS IS NOT FOR SCUT MACHINES WITH SHORT REAR TIRES.
$560 FIRM, CASH ONLY, MUST PICK UP
Located in central southern WI / northern IL just off the I-90.
- GEAR RATIO: 3:1
