How many of you guys actually drove a model T. ?
Had a neighbor "try" to teach me " once ". A lot going on there. Thank goodness for New and Improved..!
I would like to drive one even. I would say it was the start of non shifting tranmissions so to speak.
Engine Specifications 22.50 horsepower
Spark plug firing order 1-2-4-3. 1 is on the radiator side
of the engine.
Spark Plug Gap .030"
Piston Specifications Cylinder Bores 3.750" Diameter 6.752" Long Diameter: Skirt 3.748" 3.749" 2nd Ring 3.743" 3.745" Top 3.738" 3.740" Ring Grooves 1/4" x 13/64" Deep Pin Bushing Diameter .740" .741" Wrist Pin Diameter .740" .741" Wrist Pin Length 3-1/2" Ring Gaps (original rings) 3.750" Top .003" Center .005" Bottom .008" When installing any type of piston, the split in the skirt
faces away from the camshaft.
I've owned and driven Model A's but not T's. Couple years ago I looked into purchasing one but after doing some research decided I was too big for it. People were a lot smaller in those days. Driving one is rather complicated and then there's the fact that most of the time it will just be setting in the garage.
Driving on is still on the bucket list though.
