Help
Magik
Active Member
Hi guys can you tell me what this bar is coming from my Briggs 18 v twin please
If the engine is hinged on the other side, you lift up on that bar to slip the drive belt. Un hum! Or it could be the chain oiler.
Many Engines were fitted with different oil port locations , and one was used while the others were capped or plugged off, if you have two my guess is the guy who owned it decided to use the different port than the original factory location
