Where can I find a ignition switch for a Sears Super 12 Tecumseh engine, I've read that if I use the wrong switch it can fry my coil, this one has the starter generator. I've checked everything and not getting fire.
If you post a picture of it along with a good picture of the back terminal's (there should be letters on the back) I'm sure someone here can help you out..
Yep I'm pretty sure its a ground the later Suburbans had a fiberglass/plastic dash so it needed a ground wire from the tractor to the switchThe "R" looks to be ground as there is copper under the terminal that goes to the switch housing. I've never seen an R used for ground. Look The M goes to magneto to ground out ignition and kill it. If the switch still works some, you can test the R to be absolutely certain. Put volt meter on ohms and with key in off position there should be connection between them and when turning key to any other positions there should be an open line between R and M.
It's using B,M,A,SDo you know what terminals were being used ?
If I'm seeing it correctly.. Clockwise..
B
A
M
S
R
L ?
