IH Cub Cadet 50C deck
chieffan
What blades are you guys running on this 50" deck that is picking up the wheel track OK without cutting it short? What I have run into is the deck has to be low for the blades to create enough suction to lift the grass from the wheel track to cut it. The CC 759-3813 blades are what CC call hi lift. Nothing more than a standard blade with a bit of lift bent into the back side.
