I hope this all post ok, I'm down to using my phone since my internet has been out all day.
Anyway, the old John Deere 420 has been running and mowing great. I mowed 4.5 acres with it and it didn't miss a lick. HOWEVER, when I was finishing up the belt on the deck came off. I drove the mower over to the shope to take a look at it.The belt just fell off of one pulley. I put the belt back on and then I turned the deck on at a idle. The belt waved back and forth and then fell off the same pulley. I called it quits since it was already late evening. The next day I looked over everything. All the spindles are tight, no loose or bad bearings. Nothing wobbles or has unusual play. I put the belt back on and turned the blades on when running at a idle, the belt did not come off, but the belt sure jumps around a lot. I throttled up a little and the belt seems to have a lot of movement and it flaps around a lot. My brother stopped by and he took a look at it and he also has no idea?. I pulled the mower deck and I noticed when I turn the PTO shaft by hand, the tensioner pulley almost works like a cam. When the pto is turned the tensioner arm slowly moves (about a inch overal) then as I turn the pto the tensioner works it's way back and the it starts over the process. I checked and no pulleys are bent and there is nothing stuck in a pulley. The spindles also do not look bent. I have no idea what the problem is? Anyone have any thoughts?
