Good thing is I remembered some things I learned about the charging system on the Onans. Been having issues with the Massey not charging the battery lately. At first I wrote it off as the ammeter not working right because I barely use the thing. After not being able to crank it over the other day I knew the ammeter was right. LOL
So last night pulled it into the garage and used my voltage meter and I had good A/C voltage coming from the stator or whatever it may be called. Checked the voltage coming out of the rectifier and even at full rpm I could only get 3.8 volts. I ordered a new rectifier from Bolens 1000. Just need to charge up the battery some more. Going to take it up to the campsite to level out some stone tomorrow.
