No spark
Chaser
Well-Known Member
I need some advise. Trying to get the fresh K321 fired for the JD 214. I am getting no spark at the spark plug. When I put the multi meter on the coil with ground on negative side of the coil I get 0.0 volts. meter ground on battery or the body/frame I get 12(ish) volts at the coil. I ran a jumper cable from the negative side of coil to the battery and still no spark at the spark plug. Thoughts? Points, bad coil (brand new)?
