I have a copy of the owners manual for the Satoh Beaver tractor. One place in the servicing section it says the engine oil is also the hydraulic system oil with no mention of what oil to use. In a chart in the same manual is shows to use a multi grade 10W oil. Then later in the servicing it states the gear case fluid is also the hydraulic fluid and to use a EP 80 gear oil. The chart says to use ATF 220.
I have never heard of using the engine oil to supply a hydraulic system. Logic tells me that the engine should get a 5W 20 Diesel Oil. The gear case, which would also serve the hydraulic system would get the ATF 220. This is a late 1970's build tractor so will probably use the Northland Transdraulic oil, same as I have used in all the Bolens and Cub Cadet hydro as recommended for several years. Lot of changes in oil in 50 years.
Anyone have any comments or suggestions to make sure I am going the right direction with this?
