I found this on letgo, and picked it up today. The guy said it’s been sitting for 45 years while texting, but when I was there he said 20 years, so I don’t think he knows. He told me that it was owned by an apartment complex.
The serial number checks out to be 1967. The gas tank is off of it, so I’m not sure what that is all about. The coil wire goes right to the battery, so that will need to be remedied; I will just replace all of the wires on it, which is not many. It has quite a few things welded to the frame here and there, so those will have to be cut off. The steering column is destroyed, but the box is good so I may be able to replace the sleeve and be ok, if not I have a couple spares. The front tires look like they have almost no time on them, they still have molding frillies on the tread; however, the rear tires are worn and cracked pretty bad. Also, one of the rear wheels is probably 8 inches wide. I have a set of truck tires on wheels that I will likely mount with some tire chains.
He also gave me a spare engine, bellhousing, and clutch. The engine is a Briggs, while the tractor has a k301. There is no starter on the tractor now, but the spare engine has one that I will put on.
I will monkey with it some over the weekend, but if it takes more than a few hours to get running I will put it off until I get some other projects done. I hope to work this tractor, so I don’t want to restore it, but a decent paint job would be nice.
