S Siman Well-Known Member Member May 21, 2021 #1 How much gear oil should be put in the final drive of 76 2414?
MFDAC Tractorologist Senior Member Member May 21, 2021 #2 Here is a link to Tractor Data's page on PK 2414. Hope this helps. TractorData.com Power King 2414 tractor transmission information www.tractordata.com DAC
Propane1 Tractorologist Senior Member Member May 22, 2021 #3 I’m guessing there would be a drain plug and a fill plug. Fill up until oil comes out fill plug. There are members on this site that will know for sure. Noel
MNGB Tractorologist Senior Member Member May 23, 2021 #4 Hi ask posted fill till it starts to flow out the check plug, or 1.5 US PTs, the check plug is located on the front inside of the dropbox
S Siman Well-Known Member Member May 24, 2021 #5 Ahh. Didnt see the fill to plug. Make sense now. Thank you sir.
