I got a Simplicity 3416 from my brother last fall engine needed some work found the exhaust valc=ve had bent replaced it and the engine runs great but for the life of me can not get the deck drive belt to saty in place,. Mowing around the shop take 1 hr with the Sears Suburban I've tried 5 times now and have yet completed a mowing with the 3416, about a week ago I got 45 minutes of mowing and the belt came off reinstalled it and finished mowing,, thought I check out what might be the problem looked in the manual the PTO has to grooves manual says install the belt on the inner groove belt was running in the outer groove so could this be the problem I moved to the inner groove this required moving the tow idler pulley to align did that so this morning I needed to mow out I went made 3/4 round and no deck sound looked and the belt was off disgusted I went back to the shop got the trusty Husqvarna out and mowed no problems mowede like a champ. When I got back in the shop took a quick look at the 3416 only to discover not only did the belt pop off it is now tightly wrapped around the PTO pulley and clutch assy looks like I;ll be cutting it off so its batting 100% have not really finished once yet
