On the Case 224 snowblower, the handle to turn the chute back and forth, was always down low. You had to bend down quite a bit to reach the handle. Which made it sorta awkward to use. So I made an extension to raise it up. It’s a lot better now. But still not enough snow to try it. But I know by just sitting on the seat, it’s going to be much better.
So the crank went thur the crank holder where I put the bolt , to hold the new extension on.
Is this the factory place for the crank to go thru ?
Ok found more pictures. But it’s hard to see where the crank was originally.
Any way, it’s going to be a great help having it up higher, and I can basically sit straight up and use the crank, where as before I had to bend to my right to get the handle.
