Completed some routine maintenance on the 1984, I'm posting because of the discussion early about the Kohler K361 18 hp engine. Today I removed the cylinder head cooling tins to check for built up crud and oil leaking. As I posted before this engine has to have clean cooling fins and no oil leaks from the overhead and I generally do this annually in the fall but this year it got to be winter. So got the tins removed and everything looked good no oil leaks cooling fins had no crud and buildup on them so I washed them down anyway and reinstalled the cooling tins.
