Got My MTD 960 running today. When I check voltage at battery with it running I get about 12.8 volts. Amp meter is not moving.
I haven't had a starter/generator before. With it running there is no voltage at the 2nd terminal of it.
Should I see voltage at the 2nd terminal of the starter/generator or does the regulator tell it when to put out voltage?
I figure the S/G puts out constant voltage and the regulator switches it on and off as needed, maybe I'm wrong.......
