Starter solenoid switch for 18hp Craftsman 2
Is it a 3 terminal or 4?
The two big terminals on the top is easy, One goes directly to the battery, the other to the starter.
Small terminal usually goes to the key switch (S) terminal. This is usually a white wire that also travels through several safety switches.
If you provide a model # a proper diagram can be obtained.
