Had a little accident over the winter that left my plastic dash trashed and my steering disengaged. The plastic I can probably repair myself but could use any help from anyone who has had to do a repair. My biggest concern is the steering, the sleeve that the steering post goes through has broken off at the base of the steering assembly. The steering wheel is rusted on to the steering post to the point where it is virtually impossible to remove which means the plastic part cannot be removed without removing the steering post sleeve and steering gears. I have everything apart except the steering post from the (pinion gear?) don't know if that is the correct name. Anyway my question is, haw does this come apart? i assume there is a roll-pin but can not see one yet,(need to do some more cleaning)
I know this is not the best description of my problem but someone may have had this problem in the past or have done a restoration where the tractor has been completely disassembled
