Wet sanding paint.
If it were me I'd start with 400 grit wet and when your to the point that most of the orange peel is gone switch to 600. After this it would be rubbing compound. I use a bucket of water and a large sponge to keep the surface flushed. You need to be very careful near corners and tight radiuses or you'll go through the paint.
