Yes the hood fits over the fuel tank, there is a simple dash of sorts it is a vertical metal support panel would have had ignition switch, choke pull, light switch if equipped, some had ammeters some none, throttle was generally mounted on the steering column, I've had good luck with the 20/30 dollar aftermarket carbs available on either Ebay or Amazon, and points and condensers are also available there the coil is just a common auto 12 V coil Spark plug wire generally wire core SP is a Champion H10C exhaust is 1" pipe and I use the pepper can muffler. Here's a picture of an older short hood model with starter/gen but the panel on yours would be about the same without the gen hole I'l look tomorrow for better picturesI need to figure out just what's missing and then decide what to do. The engine is missing all electric/ignition related parts along with the carb and exhaust. So the hood just wraps over the fuel tank? is there a dash piece on the back?
The clutch sounds normal and good they don't have much travel are a bit stiff there are no adjustments, yes check all the gearbox's for water if it sat outside if the the shift boots are missing they will have water in there,, there are no seals on the trnny input or output shafts so if the front trans overfills it will run into the second one and then on into the differential and then into the final drives, if the hydr pump can be turned by hand I wouldn't open it up that is a Century fox unit also used on Cub Cadets Wheelhorse's and Bolens I recommend getting the thumb drive that has over 34000 pages of information on the Power King tractorsThanks for the info, GB. I'm sure I will have many more in the future. I need to open up the engine, gear boxes, and hydraulic pump and see how they look inside. Never know how long these things may have sat with water in them. The guy we bought from said he had them opened up and filled them with 30w when he mothballed the project. I don't know what the clutch is like in these, but this one sems stiff and not much travel. It does seem to release though.
