My PK 1620 is a real nice tractor but it has about 1400 hrs on it and needs a few things repaired and updated, first off someone previously disabled the saftey switch's (all of them) I'm not a fan of the seat switch really like and want a PTO saftey switch and a neutral start, second the engine was using some oil and leaking making a big mess so I decided to make some repairs. I ran the engine with the air filter off and could put my finger over the crankcase breather and there was not any real blow out in fact there was as much sucshion as blow that told me there wasn't really any blow-by did a compression test and it was about 70 PSI on both cylinders so that's good both even (this engine has ACR), also the ignition module was acting up having weak spark on the left cylinder. So I removed the engine from the tractor removed all the cooling tins what a mess oil grass clippings everywhere, washed it down a couple of times did some scrapping and finally got it clean. Removed the PTO clutch and the flywheel to check the crank seals, could see that the PTO seal was not leaking but it had been previously replaced and was not square in the bore, looking at the flywheel seal it looked ok, but it was leaking so I ordered new seals and a new ignition module
