Before I ended up in the hospital I had started the heater install, was having a time of it now I realize the the head injury had a lot to do with that. Anyway the heater came and I unpacked the box laid out the part to check things out and then started working on the install. Things go a lot slower now but its getting better. I fabricated a mount for the fuel tank. got the tank attached to the mount. Looked for the outlet found nothing (and as CVANS posted the instructions are a bit weak) figured there must be a nipple that you drill and install. looked everywhere could not find a nipple I was looking for a rubber bushing and a push-in nipple. So I PM'd Chris and asked him about, he was kind enough to look in his left over part as he didn't use his tank . He found the nipple and misc parts in a small zip lock bag inside the tank and he sent me a picture, now I remember removing that bag so went looking and there it was and I had looked at that bag at least 3 times but never opened it ande I thought the nipple was a special fastener as its metal with threads not what I was looking for. Had file off a flat area as there is a rib all around the tank drilled a hole now it to figure out how to get the nipple in the tank and in the outlet hole, I got a gas welding rod put the inner O ring on the nipple slide it on the welding wire and it dropped right into the just like was needed put the outer O ring and some pipe sealant on the threads and tightened the retaining nut. Installed the assembly on the B2601 along with the fuel filter and then the fuel pump
