This is my three of four tractors I wanted to get done over the winter so I’m running real late but it’s getting done. I’m not doing anything cosmetic so it’s just routine maintenance. The battery tray unlike the 3415H is in good shape. So far I’ve changed the oil with a little MMO added, changed the air, fuel, oil, and hydro filters. I added a little hydro oil it has a quarter size leak over night. Right now thats not a problem to worry about. I cleaned the spark plugs and noticed a lot of rust inside the plug wire cap. I took a stone wheel used to sharpen a chainsaw and put that in my cordless drill and got them cleaned up. I sprayed them out with carb cleaner now bright and shiny.
Next up I’ll be taking all the pulleys off and get them cleaned and check the bearings. These Simplicity tractors have more pulleys than any other tractor I’ve worked on. One bad pulley on these can destroy a belt.
