Last summer I installed an electronic generator controller to replace the old mechanical voltage regulator, the old VR was mounted on top of the starter/generator and under the hood, removing the hood on this tractor is a PITA so I just made a mount for the new VR an mounted it outside the hood. Monday I removed the hood and the old VR fabricated a new mt of the new VR, got the mount completed this morning and installed the regulator, everything cleared and fit with the hood installed got most all the wiring reconnected, started the engine and most everything is working, the lights aren't will have to figure that out this afternoon and I need to reconnect the mag switch and it should be good to go
