So I finally started on the JD140H3 to get it ready for winter. Took the deck off and cleaned it. Put in storage. Oil change, greased 12 nipples, lubed other moving parts. Put the thrower on. I’m amazed that I found the thrower belt amongst the junk. Greased and lubed thrower. Put the deflector cylinder on. Checked operations. Checked air filter and hydro fluid. Put my wheel weights on, that I bought about six months ago. Put the rear blade on. Has teeth on it to ruffle up the ice, so we don’t fall down while walking to cars. Checked tire pressures.
