I was using my 8n yesterday, it was working fine for about an hour, I got off to angle the blade, and when I got back on, the clutch would not disengage. I couldn’t get it in gear, it would just grind. I shut it off, put it in gear, and started it and drove it back up to the garage. Stepping on the clutch pedal did nothing. I shut it off again, put it in reverse, started it and now the clutch was sort of working. It would stop the tractor, but I still couldn’t get it in gear without grinding. The pedal has no resistance until about halfway down. I don’t see anything obvious with the linkages. I will check that everything is adjusted right, but I don’t imagine that would change so suddenly. I’m guessing something broke and I’m probably going to end up having to split the tractor, but before I do that, does anyone have any ideas what I could check or try?
