Finished adjusting and greasing the haybine and tried it out this evening in a the small field where our orchard is. Its under 1 acre so it works nicely as a test plot. This is as early as I can remember starting the hay. Still plenty of moisture in the ground as I was leaving muddy tracks in a few spots. Not a lot of hay on this field but hopefully that will help it dry quickly. The haybine held together so far and cut pretty good. Now to get the tedder hooked up and see if I can get the baler going also.
