I got this trailer, as just an axle and frame several years ago. I put the sides on, and have hauled many many, cords of wood, yards of dirt and mulch, and rocks since then. You can find a build thread from when I built it HERE. It has been serving me very well, and I don’t see any reason it will not last many years to come. Last fall, I noticed a hole in the plywood deck that rotted through. Today, I decided to take a few hours to clean it up with some paint, and replace the wood. I did not get too crazy, because this summer I plan to build a trailer that won’t require a shovel to unload it...
Here is one of the many loads of wood it has hauled.
This is how the trailer looked a few hours ago, when I pulled it to the garage.
I made quick work of removing the wood.
Once I got the wood off, I saw how bad of a job I did with my corner supports! In my defense, I think I was 14 at the time.
I don’t remember if I greased the bearings when I first started using the trailer, but I would bet against it. I drilled and tapped a hole in the hub so I can squirt some grease into the bearings whenever I feel froggy. The hubs don’t have dust caps, and the bearings were usually lubricated by mud and water from the wet areas of my woods. I tried to find dust caps today, but I came up empty handed. They are 1 15/16” which seems to be an odd size. I do not mind, this will give me a Good first project once I get my new to me lathe set up in the next few weeks if I still can’t find caps.
By the time I got back from getting wood and paint, it was getting dark. By the time I finished painting, it was dark. I did still take a low quality picture; I will get more pictures tomorrow when it’s all buttoned up with the wood.
