And our skin is getting thinner.I blame so of it on the Meds I take
I guess so that's what my Doc says, I bruise so easy now and she said as we get older (what me) we lose the fat layer under the skin and so the small caps brust easier I asked her if eating more donuts would help she said I don't see any bruises on your belly so NOAnd our skin is getting thinner.
Sounds like a good doctor.she said I don't see any bruises on your belly so NO
I have to do the other (more difficult) side now...the one with the tension spring in it that bit me when I installed the door 12 years ago.Nicely done, that should last forever!
When you find out what is wrong post it here as it sounds like my door. Mine started doing the catching and b going back up about 3 years ago, the spring on that side was loose and the wheel the cable ran on the bearings were gone, changed the wheel and tightened the spring and it worked good for a year and a half and now it is back doing the same thing with a new twist of not wanting to go up sometimes. Only been in for 23 years.Nice fix floater. Haven't seen they style of roll up door in a long time.
I have a door that needs something. Been in for 19 years and last fall it started to keep working to one side. Gets so far then when the door is about 2' from closed it stops and goes back up. I can grab the door and shift it to the other side and it is good for a dozen or so cycles. Tried changing the spring tension about 1/2 turn on the torsion spring and didn't help any. Might have to break down and try U Tube but I know I will get sent 40 different directions before I get close to what I want.
