Got the Simplicity 3416 into the shop from its winter slumber this is the one I replaced the bad exhaust valve in last fall, battery was pretty much dead from sitting (and its old) so with a jump battery got it running and it runs good but the darn B&S Flo-jet carb leaks if you don't shut the gas valve. So I got the deck in and checked it over blades were pretty good but I sharpened them, greased the spindles reinstalled the blades turned the deck over and removed the deck covers found a mouse nest under there and it was wet from the rain we had, got it cleaned up and found a bad spot on the deck belt so replaced it with a new one got it all reassembled, this morning got it back under the tractor and all attached and the drive belt reinstalled. Started the engine and engaged the deck clutch and it was working a bit noisier than a few years ago but ok.. I plan to mow with it some this spring/summer as its 48" and a hydro will give the Suburban a little rest
