I repaired a hydraulic leak and then changed hydraulic fluid (JD TY6354) and filter on my 430 JD and now it won't move. Power steering and three point work fine.
HELP
HELP
Jack rear up with tires off the ground and run her while cycling forward then reverse, and repeat till you purge the air out of the system. May take a few minutes.I repaired a hydraulic leak and then changed hydraulic fluid (JD TY6354) and filter on my 430 JD and now it won't move. Power steering and three point work fine.
HELP
will do--thanksJack rear up with tires off the ground and run her while cycling forward then reverse, and repeat till you purge the air out of the system. May take a few minutes.
Good idea.If you push down and back it should move a little easier, learned that trick with my 420.
